Okay, My teener seems to be running too hot and I got a TSD rally to go to tomorrow. I have had the car off of jackstands for about 2 weeks now.
Last year before the rust repairs (see the link in my thread) the thing ran 180 to 200 degrees all day long with no problems sitting in traffic or on the highway.
Now the engine will idle at 180 degrees all day with no problems. After about 15mins of driving temp gets above 200 and just seems to keep climbing, unless the engine slows down to idle speeds, then it drops back down to 180. I have let it go to see how far it would go and about 230 I quit as it was still going up.
The engine is a carbed stock 1.8L with a recent rebuild. It has an external oil cooler / with an electric fan. I removed and replaced the engine during my rust repairs.
Here are the only things that changed on the engine...
1) Rebuilt both carbs (Dell 40s)
2) New plugs / wires / ditributor cap /rotor (and it was timed again)
3) Changed the oil
4) The car has a tuna can sump and when I took it off I noticed that the screen was facing down, I believe that is supposed to go in facing up so I changed it.
Everything is really clean and it seems to move the air really well. It runs pretty good with a little righness at idle. Oil pressure is 20 psi idle and 50-60 psi at rpm.
Any other suggestions? I need to cool this baby down to drive in the rally tomorrow.
