r_towle
Aug 12 2005, 08:06 PM
Replacing the rear proportioning valve with a tee fitting???
Will this make is brake more during autocross?
And, is this a standard plumbing tee, or is it special???
Rich
campbellcj
Aug 12 2005, 08:40 PM
Tons of info in the archives (search) -- first questions are, do you have stock brakes? Tires? Track, autox or street car?
The tee itself is a brake specific part; most use a VW tee available for like $10-20 at typical bus/bug shops.
r_towle
Aug 12 2005, 08:58 PM
I have searched, no quality results...
We need a better search engine.
Thanx for the response.
Rich
Aaron Cox
Aug 12 2005, 09:00 PM
Rich,
I just installed one, got it from someone, who bought it from James Adams....
available at ANY big shop for under 10 bucks...
think of it as a P -valve that is wide open....
gives MORE power to the already undersized rear brakes
r_towle
Aug 12 2005, 09:01 PM
is this tee fitting a stock part on a beetle???
I have two out in the barn...If I can steal it, that would be good.
Rich
Aug 12 2005, 09:02 PM
QUOTE (r_towle @ Aug 12 2005, 07:06 PM) |
Replacing the rear proportioning valve with a tee fitting??? |
stock brakes, no T ...
bigger brakes and MC, the T will give you more bias towards the rear, which is a gud thing as bigger brakes tend to favor the front.
key is, you want the front to lock up just a millisec before the rears and not the other way round.
the "Tee" can be had at every VW-Bug shop for $5+ ...
Andy
Aaron Cox
IIRC yes.....
go look
and report back
Eric_Shea
Aug 12 2005, 09:06 PM
Mark your calendar... I agree with Andy
Marv's3.6six
Aug 12 2005, 09:19 PM
An adjustable proportioning valve is the best way. I am doing one in cab like the pic. The trick has been finding one with all metric connections, found at PMS.
Aaron Cox
Aug 12 2005, 09:22 PM
Marv,
why go with the handle type when it only has ~6 positions, why not use the knob type with infinite adjustability????
AA
Marv's3.6six
Aug 12 2005, 09:25 PM
Cuz the range of adjustment is the same in both types of P valves, this type lets you know where your at by touch or visual.
Aaron Cox
Aug 12 2005, 09:26 PM
QUOTE (Marv's3.6six @ Aug 12 2005, 08:25 PM) |
Cuz the range of adjustment is the same in both types of P valves, this type lets you know where your at by touch or visual. |
good to know. thanks marv
-Aaron
Aug 12 2005, 09:31 PM
QUOTE (Marv's3.6six @ Aug 12 2005, 08:19 PM) |
An adjustable proportioning valve is the best way. I am doing one in cab like the pic. |
except, unless you've got HUGE rear brakes, we always end up running the adjustable proportioning valve "full open" which is exactly what the $5 "T" does for you ...
Andy
Marv's3.6six
Aug 12 2005, 09:41 PM
I'm runnin the new Brembo GTP Lightweights, they are beeeeeg.
Aug 12 2005, 09:42 PM
QUOTE (Marv's3.6six @ Aug 12 2005, 08:41 PM) |
I'm runnin the new Brembo GTP Lightweights, they are beeeeeg. |
they sure are ...
