QUOTE(porschetub @ Apr 27 2023, 06:58 PM)
QUOTE(cdn914 @ Apr 13 2023, 08:45 AM)
Has anyone installed a JWest Headlight Relay Kit (designed for early 911s) on a factory 914-6?
Whats the benefit of these ?,thinking reduced load on light switch and an improvement in lighting with stock size lamps ? ,we are 60/55 W for H4 ,anymore you would fail inspection here.
TIA,cheers
The factory early 911/914-6 turn signal switch is almost unobtainable these days, and very expensive if you do find one. All of the headlight bulb load flows through it. So adding relays will increase the life of said turn signal switch.
Just an FYI, it is normally recommended to mount the relays as close to the headlights as you can. I installed them on my big six long before LED bulbs were available, and was able to run high powered halogen bulbs with on ill effects.
