QUOTE(StarBear @ Apr 16 2023, 07:51 AM)
@L-Jet914 @wonkipop Took LJet’s suggestion and tried SAE Allen wrench. 3/32 worked perfectly.
Why SAE in metric car? Different supplier? Changed out when cable replaced a few years ago? Strange.
i would guess that your grub screw and pivot were replaced in incident you mentioned in earlier post with a very similar fixing that was USA (imperial) sized. i'm thinking the little grub screw throttle cable fixing is a reasonably common fixing available both in metric and imperial sizes. or they lost the grub screw and put another one in with correct thread but an imperial sized hex for the allen key.
all i can say about mine is i have only metric allen keys so i'm thinking mine must still be metric or i would not have gotten it off 3 or 4 years ago. i think
@L-Jet914 is correct.
someone maybe replaced yours like for like but imperial sized.
everything in writing in both PET and factory workshop manual describes the fitting as a fillester screw. ie a conventional screw with a head on it. which i'm guessing all the other 914 variations have. we have a grub screw fitting and there is only one place it is shown as an illustration, but there is no listing of it saying/listing what it is. a typical little detail that slipped through the proof check on the factory manual and the PET catalogue.
at least a 914 is not like an aussie ford.
australia converted to metric in 1974 (same year as my 914). but they were still making aussie fords with many imperial size bolts and fixings in them nearly all the way to the end of manufacturing here. the falcon ute (1994 model) i restored was exasperating as it was a mixture of imperial and metric depending on what component you were trying to take off or take apart. nuts.
luckily mike has a full compliment of tools in both metric and imperial. i have no imperial tools.
