74forsche
Apr 15 2023, 04:37 PM
https://w3dparts.com/?product=914-headlight-deleteW3dparts has a headlight delete kit ready! If you are looking for a lightweight option that can remove the old pop ups...give them a look!
Apr 15 2023, 06:28 PM
I love the pop ups.
ssstikircr
Apr 15 2023, 07:18 PM
It would look better with some kind of lens over the lights
74forsche
Apr 16 2023, 11:15 AM
QUOTE(ssstikircr @ Apr 15 2023, 08:18 PM)
They look much better in person. They are a huge upgrade in light and function and if deleting entire headlight bucket, significant weight savings!
Apr 16 2023, 11:25 AM
QUOTE(74forsche @ Apr 16 2023, 01:15 PM)
Headlight motors are 4.5lbs. Probably another 2 lbs for headlight and sheetmetal. 13 lbs. total. Get GE truck-lights if you want mind blowing headlights. 5 minute swap.
74forsche
Apr 16 2023, 04:13 PM
QUOTE(mepstein @ Apr 16 2023, 12:25 PM)
You need to reweigh some stuff there.
74forsche
Apr 16 2023, 07:29 PM
So the pop up headlight and motors weigh in at 30lbs. The sheetmetal removal would be at least 20lbs...so 50lb weight reduction is there
74forsche
Apr 26 2023, 08:32 PM
Theses housings are polycarbonate carbon fiber. Light and strong. They can be sanded and painted or clear coated. The lower bulb is low beam. The upper is high beam. Both are lit for high beam. The upper bulb is also the blinker....as these lights are dual function. The small middle bulb is the running light. Our focus with these is for restomods, v8 conversions, and track cars. The lighting improvement is significant.
74forsche
Apr 26 2023, 08:40 PM
We will shortly have an entire tail light housing replacement. To compliment the headlights. Again polycarbonate carbon fiber. Bolt in and connect !
rhodyguy
Apr 27 2023, 08:13 AM
What is the thing with the orange handle?
74forsche
Apr 27 2023, 12:50 PM
QUOTE(rhodyguy @ Apr 27 2023, 09:13 AM)
Magnetic ground for welding/plasma torch.
74forsche
May 17 2023, 09:25 AM
These deletes can be used With the stock headlight as well. If you are just want to add better lighting and turn signal function.
jim_hoyland
Jul 9 2023, 07:50 PM
Very cool; innovative.
