David Mueller
Aug 13 2005, 10:37 AM
I need to replace my transmission drive shaft oil seal and I have to remove the drive shaft (CV joint) bolts first. What size driver do I need for them. It looks like a TORX head bolt is it metric like a 8MM or what...I wanted to go my local tool store and buy the right driver but I didn't really want to buy a set of metric and SAE just to see if something would fit.
Can anyone help ?
Porsche Rescue
Aug 13 2005, 10:50 AM
8mm, 12 point is what you want
David Mueller
Aug 13 2005, 11:04 AM
Thanks ! On my way to find one right now.
ArtechnikA
Aug 13 2005, 11:53 AM
just for anyone following this thread or who landed here by way of a search some day...
THEY ARE NOT TORX!!!
they're "triple square."
those happen to be 8mm. some 911's use 10mm triplesquare CV bolts. early 911's (i.e. 914.6 - for context...) use 12mm trible square flywheel bolts.
dmenche914
Aug 13 2005, 12:09 PM
i believe the bolt head is the same as on the VW Rabbit, that might help you in the search as some parts stores these days are so dumbed down that they can't find a part or tool by discritpiton, they only can find it by giving a make and model of the car, go figure.
Cap'n Krusty
Aug 13 2005, 01:19 PM
QUOTE (dmenche914 @ Aug 13 2005, 10:09 AM) |
i believe the bolt head is the same as on the VW Rabbit, that might help you in the search as some parts stores these days are so dumbed down that they can't find a part or tool by discritpiton, they only can find it by giving a make and model of the car, go figure. |
The bolt itself is the same as a VW bus, bug, rabbit, golf, jetta, 924, audi 4000, and a few others. Early 911 is different. 8mm "triple square" wrench size/configuration. NOT TORX, as Rich said. The Cap'n
JFJ914
Aug 14 2005, 10:10 AM
Lisle tools blister packs the triple square (XZN) bits. Set is available at most FLAPS.
