QUOTE(jd74914 @ Apr 24 2023, 03:48 PM)
QUOTE(windforfun @ Apr 23 2023, 09:21 PM)
I worked with high power lasers for many years. In fact, I designed many optical systems that used them. I used to have to get my eyeball retinas inspected & photographed for damage. Be very careful with that motherfucker & were safety goggles that filter out that wavelength. Be safe & don't fuck around with the thing.
Wavelength, output power, & class? Wear the appropriate safety goggles!!! No shit.
The reflected &/or back scattered light is potentially harmful too. And remember, don't stare directly into the beam with your remaining eye.
Yes, please do that. If you want to add the Wavelength/power/class we could even suggest PPE. My background is as a high power laser user (experimental laser diagnostics) and proper PPE is essential if you wish your eyes to stay safe for years.
Not sure who made this one, but some cheaper laser off Alibaba and other import shops have multiple modes because of poor filtering and internal optics so you really need wide range googles. Our radiation safety people did a bunch of testing on import lasers and learned a) not to trust the manufacturer and b) absolutely not to trust their goggles.
This unit is essentially the same as every unit being offered of this size and type. All made in China, as most things are. The laser itself is a Raycus 1500w 220V unit. Link below to the one I bought. It came with glasses and I bought an extra pair for observers. I tend to stay at 500W and below, depending on what I am doing, and the beam width I am using. I use the glasses during operations. The only thing I plan to include is a mask since my exhaust system is not adequate and I will be needing to build up a better one since I cant just open the door and fan out the fumes during winter.
For the goggles, is there a test to show that they work or do not?
Here are more technical parameters:
Laser Source: Max Laser 1080±5 nm fiber laser
Laser Output Power: 1500w
Safety: Class 4 Laser Device
https://www.amazon.com/Handheld-Welding-Mac...C435&sr=8-5
