r_towle
Apr 24 2023, 02:57 PM
76 2.0 Djet
What is the proper routing for the drivers side fuel supply line to the injector rail?
Just going in to replace all engine bay lines and the driver side is laying on top of the motor, and does not seem right.
What do others have?
Rich
76-914
Apr 24 2023, 06:00 PM
Mine lays on the engine as well.
emerygt350
Apr 24 2023, 06:08 PM
Yep, but not right on it... Mine goes up over the oil fill etc.
r_towle
Apr 24 2023, 06:13 PM
Same, just seems kind of sloppy, but okay Dokey
914werke
Apr 24 2023, 06:17 PM
OG there was a plastic like sleeve over the rubber line presumably to protect against heat or chaffing.
wonkipop
Apr 24 2023, 06:29 PM
74 L jet. similar i'm guessing
as
@914werke says - fuel line runs inside plastic sleeve which clips to side of front inlet runner. clips are spot welded to runner.
