QUOTE(r_towle @ Apr 24 2023, 07:41 PM)
I guess you are changing what comes out of the tailpipe….but are you really reducing the bad gasses by burning them??
Seems that making the engine more efficient would be better overall.
yes. you are.
but - its not really gases you are burning.
its unburnt hydrocarbons. tiny droplets or particles of long chain hydrocarbons.
ie fuel.
the gases get dealt with differently.
NOX - primary cause of smog was dealt with by ignition timing.
CO - carbon monoxide - by turning it into CO2 (slightly more harmless) and H20 using the cat. some hydrocarbons are also dealt with in the CAT by chemical conversion and absorption.
the 75 L jet did not need the air pump.
it ran EGR + CAT in california and did not have EGR or CAT in 49 states.
basically L jet could run more cleanly ( i don't think efficient is necessarily the right word but i guess sort of more efficient).
the D jet 2.0 california ran the smog pump, CAT and EGR.
the D jet 2.0 in 49 states ran only the smog pump i believe.
i guess D jet needed the smog pump at that time to make it through.
these were not sophisticated computers running the EFI.
though they were in their time and a lot more sophisticated than a carb.
but good as they were they still had trouble meeting EPA and CARB.
things got tougher in 76.
the 912E with the same 2.0L engine and running L jet needed a smog pump.
so i guess L jet couldn't quite get there by a year later either.
with smog regs the EPA and CARB revised their approach around 72 to cooperate with car manufacturers and available tech. they went after NOX first and delayed the stricter HC and CO limits. NOX was mainly done with ignition timing. thats what the double can distributor is all about.
they toughened up HC and CO emissions from 75 on in california (CARB) and 76 (49 states). primarily that is what the CAT was for. CARB records indicate porsche and VW had a bit of trouble with the CATS getting them to last the required 50,000m.
this may have been to do with the size of the cat they could install and also its location further along the exhaust system after the primary muffler. not really sure.
but the air injection and semi thermal reactor heat exchangers probably assisted the CAT to do its job by knocking some of the HC emissions out before they got to the CAT.
@914werke is correct re the heat exchangers being thermal reactors.
they were not full thermal reactors but sort of psuedo or quasi thermal reactors.
the 912E and the 911s at that time in 76 did get full thermal reactors which are can-like cylinder shaped things that hung under the engine. because they had full thermal reactors they did not have CATS fitted. thermal reactors were an alternative technology to CATS. mercedes benz fitted thermal reactors as did BMW.
thankfully australia escaped the thermal reactor pollution gear.
it was not good for engines i believe. made them run very hot.
