QUOTE(technicalninja @ Apr 29 2023, 02:50 PM)
QUOTE(Superhawk996 @ Apr 29 2023, 02:36 PM)
The first part of your statement is correct. Increase in swept area doesn’t equal more stopping power.
The two parameters that matter most to stopping distance are:
Effective radius (distance between hub center line and the center of pressure - assumed to be the center line of the caliper piston - for sake of discussion). This is largely a fixed number determined by part geometry and where the caliper mounts with respect to the rotor.
Coefficient of friction of the pad material and how much it changes (up or down) as a function of pad temperature. This is what you can most readily tune and control.
So, what you are saying is increasing the friction footprint by 20% makes no change at all?
This upgrade doesn't change the moment arm (distance from rotor center) at all, just the pads are longer in this case.
If so, this only gain from this set up should be longevity and it's not worth doing over the same pads (manufacture and pad compound) in the stock calipers?
But, in that case it should not affect F/R brake balance at all.
From a pure theoretical standpoint, footprint (area) of the pad doesn’t come into play
From physics: friction force = normal force (applied perpendicular to the pad) * coefficient of friction
Notice there is no term for area in that equation.
It is counter intuitive, but if you increase the area, the applied pressure gets distributed over a larger area and each portion of the friction material sees proportionally less pressure than it did with the smaller pad and therefore the larger pad generates the same friction force.
But what about tires you say - surely you agree larger tires create more grip?
Well the same equation applies for tires. However, as we have all learned about tires, there are microscopic interactions between the rubber of the tire and the asphalt that sort of “interlock” the rubber to the asphalt creating more grip than theoretical physics and the basic friction equations would dictate.
So let’s acknowledge that the friction equation has its flaws for viscoelastic materials like rubber and asphalt.
Organic brake friction material like Porterfield does tend to transfer to the rotor and we do get some shearing grip between the rotor and the pad SORT of like a tire but it’s only a very small fraction of what rubber does because the pad isn’t a viscoelastic material.
Now about the effective radius - generally speaking, when caliper piston size increases, that influences the effective radius. Sometimes negatively.
A larger piston usually means a thicker caliper bridge to resist the larger bending forces generated by the larger pistons. In order to keep it all fitting inside the wheel, the caliper piston has to move closer to the hub. This decreases effective radius. But, it gets offset slightly by increased pad pressure (assuming line pressure stayed the same and that you didn’t run out of master cylinder travel).
Brake “upgrades” get messy and complicated fast as witnessed by this thread.
In order to maintain proper front to rear brake balance it is best to increase both the front and rear calipers in the same proportion. And then of course, it may be come necessary to increase master cylinder displacement proportionally to insure that you don’t run out of pedal travel and can maintain equivalent brake line pressure.
