QUOTE(porscheteck914 @ Apr 30 2023, 11:04 AM)
I worked on 914 and got park light ind bulb to light up as original . Figured out the horn and got it working . And put in fog light switch and got the fog lights to work as there supposed to . Some idjut rigged up signal lights were the original fog lights go . What da ??
That was a very popular mod, allows you to flick the high beams, except when the headlights are off the power is diverted to the fog lights. There could be a relay in the mix?
Good work so far, make sure you get a factory wiring diagram for your model year.
