Some on here have played with increasing rod length on a standard 2055 build (96X71).
I'm hoping they will share their experiences/ problems with this idea.
It appears that you can fit a 5.5" rod to a KB stroker piston (1.11 comp height) with a .070 lower cylinder shim pack and end up with a deck height of .035-.040
From Jorge@europeanmotorworks
"KB 034-100B 96 x 80 22mm pin has a pin height of 1.110" weighs 494 grams w/pin and 391 grams w/o pin."
A stock 73 2.0 piston and pin weighs 680 grams.
The rod (aftermarket H beam) should weigh somewhere around 600 grams.
I could not find a weight but my 6" chevy H-beams weigh 630. My Miata H beams (133mm length) weigh 570 grams.
The stock 73 2.0 rods are pushing 800 grams.
So, in weight reduction alone I can pull 53.6 oz out of my reciprocating assembly.
This is the highest weight reduction I've ever come across. This is MASSIVE!
I improve my rod/stroke ratio from 1.845 to 1.967.
I increase my piston dwell time at TDC.
I reduce side loading on the pistons as well.
All of these are "for the better" in my book.
The weight reduction is un-believable. Porsche/VW went HEAVY for these parts.
Am I missing something?
Are there reasons not to do this?
