914Sixer
May 1 2023, 02:27 PM
Just got these pieces finished up. Did gun barrel finish on these parts. Ready to assemble full floating axles with 944 CV's. Rear hubs are plug and play with 914-6 rotors.
r_towle
May 1 2023, 04:06 PM
when all is done, what are you using for rear brakes?
E-brake?
rich
914Sixer
May 1 2023, 04:12 PM
Stock 914-6 rear calipers. You can use stock -4 if you turn rotor down.
r_towle
May 1 2023, 04:27 PM
is there an integrated e-brake on the 911 caliper?
or is it a drum?
rich
914Sixer
May 1 2023, 06:10 PM
No ebrake is a plate mounted on the trailing arm.
r_towle
May 1 2023, 07:25 PM
Now I need to go look at my 911 to see what is up.
Ebrake still works great, but I never looked at it.
Aside from 5 lug, what is the benefit of doing it the way you are doing it?
I have the complete front sitting in a box….mainly because the rears are hard todo.
Right now, adapters.
bahnzai
May 1 2023, 07:30 PM
Looks fantastic. It is a shame to cover them up!
May 1 2023, 07:44 PM
QUOTE(r_towle @ May 1 2023, 09:25 PM)
Bigger CV's hold up better with a bigger engine. 911 hubs accept 911 rotors.
Steve
May 1 2023, 10:43 PM
QUOTE(914Sixer @ May 1 2023, 01:27 PM)
Since they’re the later hub centric, don’t they need the spacers?
914Sixer
May 2 2023, 05:48 AM
Yes, the need external spacers from Patrick Motorsports.
