Hello.
I thing I have a bent/damaged part but cannot see clearly enough in the PET to see if it is OK or not. It certainly does not look terribly healthy.
The part is the bracket that goes between the engine crossbar/carrier and the chassis mounting point. It is part number 11 in the below diagram, PN 914 375 181 00.
It looks like someone bottomed the engine carrier out and deformed the opening in the middle of the bracket (see pic below), where the big mounting bolt goes. The carrier was pushed rearwards when on the car.
So my question is whether this part should be flat? If yes, I would try to flatten it on the press.
Thanks very much.
