913B
May 2 2023, 07:59 PM
Since I have the engine out. I would like to track down a leak.
The orange rubber sealant feels wet when I touch it.
Am I opening a can of worms if I try to reseal it?
Why did the PO use the orange sealant, are the gasket NLA?
Which one is the correct gasket do I need and should I also use a gasket sealer.
The bottom bolt of the motor mount is a through bolt? It is wet also and when I took the bolt out oil came out from it. Is this normal or I have another issue?
Can anyone else chime and see from the pictures what other areas to check?
Thank you all so much
Ted
Click to view attachmentClick to view attachmentClick to view attachment
r_towle
May 2 2023, 10:30 PM
mgphoto
May 2 2023, 11:02 PM
Gasket is readily available, no sealant, loosen the bolts around it and pry the pump out using the ears.
Oil shouldn’t come out from the bolt hole, check for a crack?
Geezer914
May 3 2023, 05:01 AM
I did the opposite, no gasket, just a lite coat of sealant.
r_towle
May 3 2023, 09:10 AM
I think there are a few things there that bother me.
One, way too much goo.
two, those nuts will melt and loosen, they are "nyloc" and the nylon will melt in that high heat application.
The bolt that holds the motor mount....I do recall that there are some bolts like that on the car that you must have in place regardless because they penetrate the oil galleys. Just seal the bolt properly.
Rich
ClayPerrine
May 3 2023, 11:47 AM
QUOTE(r_towle @ May 3 2023, 10:10 AM)
Rich
Nyloc nuts will not melt on an engine. They will, however. melt on the exhaust studs.
Clay
930cabman
May 3 2023, 11:55 AM
I would look for a burr on either the cover or the case. Also check the cover for flatness. Clean all surfaces and a thin (.005 or so) if memory serves correctly.
914sgofast2
May 3 2023, 12:08 PM
If that were my engine, I would replace: (1) the thin paper gasket between the oil pump and the engine case (and use Permatex on it, not silicone sealer); (2) the o-ring inside the oil pump housing halves since the pump has to be removed anyway to check on the internal condition of the pump and check that the oil pump gear idler shaft has not started walking out of the pump body towards the cam gear; (3) the front crankshaft seal, and (4) the thin o-ring that rests behind the fan hub on the crankshaft. Why? Because you are already in there and it's cheap to replace all those seals - an engine gasket set can be found for between $60 to $80 depending where you shop and it will have all the seals needed to do this job right.
Dominic
May 4 2023, 09:14 PM
You can buy special nuts for the oil pump cover that prevents seeping from the 8mm studs. Unlike typical lock nuts, the red nylon actually goes face down.
Of course I don't have the stock oil pump on my engine.
Literati914
May 5 2023, 09:27 AM
QUOTE(Dominic @ May 4 2023, 10:14 PM)
Got a link to those or a searchable name that they go by ?
nditiz1
May 5 2023, 04:37 PM
I believe the method I got from McMark was no gasket, loctite 542 bolt it back on. I did it that way with my 2056 and it was dry before I sold it.
Dominic
May 7 2023, 10:29 PM
QUOTE(Literati914 @ May 5 2023, 08:27 AM)
I found these on Ebay, but you might find them at other VW online parts outlets. They are made by Elring, Part # 111115161
https://www.ebay.com/itm/175603807595?fits=...ABk9SR7j70Zn_YQ
mgphoto
May 8 2023, 09:39 AM
QUOTE(Dominic @ May 7 2023, 08:29 PM)
https://www.ebay.com/itm/175603807595?fits=...ABk9SR7j70Zn_YQThese are not necessary for a stock pump, the internal o-ring seals it. These are useful on an aftermarket type 1 pump, but the pump should be o-rinded before installation.
