My wife and I were all packed and ready to go to WCR19 waving goodbye, she wanted to open the window. It did; all the way. The plastic button had escaped from the moving dog. A new plastic button did not really fix the problem, but it worked for a while. Then I decided to go to the lathe and make a button from bronze and attach it so it can't fall off.
The button didn't pop off, but the window wouldn't roll all the way up. Looking closer I found this issue:
The worm gear track follows a plane. For most of the travel, the dog that actually does the lifting is sticking up, normal to that plane. That is, the grove that the dog slides through
Most of the way, the dog looks like this. Drinking straw added to make things clearer.
See, straight up and down.
But as the window gets to the top, the tube bends like a switch back on a trail. The engineers must have assumed the slot would stay straight. But it doesn't.
This is an extra track from eBay. The angle doesn't look that bad, but what it does is to wrench the dog out of the button. When they were new, I suppose that there was enough hold upon the button to make it through, but here where the dog is towards the top of the run things get stiff even if everything stays together. The top of the run is where my bronze thingy jammed. It wouldn't allow for that twist of the run.
