Does anyone know where I might be able to get the electrical connector to connect my oil temp sensor? It has not been connected since I installed the 3.0l engine. I am not familiar with electrical connector like this. See pic below, the terminal on the sensor is round.
nditiz1
May 7 2023, 07:49 PM
Should be able to use a regular female spade connector. I think that's how my temp sensor is rigged up.
Dave_Darling
May 7 2023, 07:53 PM
I believe a standard ring terminal will work; IIRC that part on the end is threaded so you can unscrew it and put a ring terminal over the stud.
--DD
mmascari
May 7 2023, 08:49 PM
QUOTE(nditiz1 @ May 7 2023, 06:49 PM)
Thanks, I think I was overthinking this. The standard flag style terminal slides right over it.
davep
May 8 2023, 07:00 AM
QUOTE(mmascari @ May 7 2023, 10:49 PM)
Yes, a regular quarter inch flag connector
davep
May 8 2023, 07:01 AM
The only trick will be the boot over the terminal.
