trick-e
May 8 2023, 10:13 AM
Hi Team,
Replacing the TB gasket, I noticed an uneven gap between the plastic/rubber spacer and the manifold. I suspect it should be snuggly mated to the manifold surface, so what gives? I gently whacked it with a mallet, but it didn’t move. Force it down into place, or is there a larger problem?
sportlicherFahrer
May 8 2023, 10:33 AM
The piece below the gasket is the steel TB mounting flange, and is part of the steel center manifold. The gap below it is normal.
Mikey914
May 8 2023, 12:29 PM
trick-e
May 8 2023, 02:42 PM
QUOTE(sportlicherFahrer @ May 8 2023, 12:33 PM)
Sweet! Thank you. Had never noticed it before.
