QUOTE(lolkema @ May 9 2023, 11:21 AM)
I always try to use the search options but each time I get about 5 million hits and I never seem to be able to find the answer I am looking for. So apologies if this has been asked before, now onto the question:
I would like to relocate the fuel pump to the front to prevent vapor lock issues. Can I use the original fuel pump or do I have to get a newer model pump? This is on a '74 fuel injected 1.8.
I did already replace the fuel lines with stainless steel pipes and replaced all hoses last year.
Thanks for the help!
First thing you need to do is decide which way you want to go as their are various routes you can take. If you want to go with how Porsche did it there are two ways, but people have come up with many more of their own as well.
Factory bulletin on relocating the pump on early cars involves moving the 3 port pump by the steering rack (though you can move a 2 port pump here as well)
The other way the factory did it was on 75-76 cars to mount it on a separate removable "bubble" panel in the front trunk under the driver side of the tank. This uses the 2 port pump, smaller tunnel feed lines, some 75-76 specific mounting parts and a hole being cut in the bulkhead in front of the gas tank.
I prefer the late style install if you have the parts to do it. I always run the smaller feed line in the tunnel for the sake of easier hose routing/no inline reducers needed at both ends and in either case (trunk or steering rack) I like to run the 2 port pump as well, again as it simplifies the hose setup.
Quickest/cheapest way from a parts sourcing standpoint though is probably going to be putting the 3 port pump by the steering rack.
