nivekdodge
May 9 2023, 08:35 PM
Can someone post a pic of their engine cover latch from on top of it? i"m thinking maybe i need to shim mine with washers?
Thanks
Kevin
Mikey914
May 9 2023, 11:40 PM
The arm on the lid is more easily adjustable.
914Sixer
May 10 2023, 06:12 AM
Make sure your engine lid is in the correct position, then adjust latch. Check for broken or bent mount.
87m491
May 10 2023, 02:44 PM
Because?
QUOTE(nivekdodge @ May 9 2023, 06:35 PM)
Thanks
Kevin
nivekdodge
May 16 2023, 12:04 PM
The arm on the lid was with in mm's of hitting the decklid. I put a spacer set in there and it works perfect now
