Geezer914
May 15 2023, 08:04 AM
Does the ground wire in the 12 pin connector wire harness going to the dual relay, plug 2, connect to the engine grounds under the plenum?
dr914@autoatlanta.com
May 15 2023, 08:32 AM
should be a male spade at the connection point for the tension clip for the bellows rod to the right front of the distributor
