QUOTE(VolksSled @ May 18 2023, 08:16 AM)
QUOTE(Geezer914 @ May 18 2023, 06:03 AM)
Just my opinion for what it's worth. You buy a sports car for the performance and handling. You buy a Cadillac for a comfortable ride. I am running 19mm torsion bars in front with 140lb. springs in the rear and Bilstein's all around. I am 75 and I like taking corners like it's riding on rails! Keeps my blood flowing and the heart pumping!
I hear that ….
I think I’m going with bilsteins all around - from paragon
New front bushings - from 914 rubber
and 100 lbs springs ( I already have the springs )
Any other component I’m forgetting while “ I’m in there”
Think James said it:
But I'll add since you asked:
Stock sway bar with adjustable drop links
Ball Joints if they are the originals.
Turbo Tie rods if they are the stock or replace the stock tie rods.
Inspect the steering coupler and replace if worn or cracked
Check the Rear Bushings for wear and trailing arm condition.
Tires are considered with the above and ride height and personnel preferences.
Springs (Progressive or personnel preference) considering driving habits and desires and tire size. I ran 140 spring rates in the rear with adjustable perches.
Shocks (struts) are last.....so again driving preferences and habits. Personally I ran progressive Billy's on all four corners because I like the feeling of riding on rails.
