QUOTE(MikeV914 @ May 16 2023, 07:27 AM)
Wow !!! Do you have another one of these kits? I'd like one as well.
Thanks
Mike
I do not. i have an aftermarket bar that have Heim joint drop links. It would need brackets made to attach it to the drop links. It would use the standard shock bolts.
All the part shown are available new.
Rear sway bars without the hardware are around. I can check with a friend who had one.
The shock bolt came from Restoration Designs. They are also available from Prekom-USA.
https://www.prekom-usa.com/product/914-sway-bar-bolt-rear/
