Geezer914
May 22 2023, 09:52 AM
Mallory Unilite on an Ljet. Am I correct using the wire from pin 7 (black/red stripe together with the black wire) on the 12 pin connector as the wire from the ignition switch? So the wire from pin 7 along with the red wire going to the distributor connect together on one side of the ballast resistor and the other side of the ballast connects to the + side of the coil?
