morehills
May 23 2023, 05:21 AM
Can anyone help me with this turn signal. The car is a '71 but I don't know if the column or mechanism has been changed. Is this a proper '71 column?
The signal works and pops up this the but does not return. What is the proper part to replace it?
Thank you for any help, John
Front yard mechanic
May 23 2023, 06:29 AM
Maybe it’s on upside down
914Sixer
May 23 2023, 02:48 PM
Plastic ears are broken off and spring is missing. This is a late switch but it will give you an idea. I may have some ears and a spring from broken ones that you might be able to fix yours with. Have to check warehouse.
Type 47
May 23 2023, 02:51 PM
I replaced mine, on my 75', with one from Auto Atlanta.
some plastic piece most likely broken, or it could be because your tach is upside down.
dr914@autoatlanta.com
May 23 2023, 03:23 PM
70 71 column with a 911 end tab put on to it. You need the 70 71 turn signal switch. we have many R91461392712
morehills
May 23 2023, 03:51 PM
QUOTE(dr914@autoatlanta.com @ May 23 2023, 03:23 PM)
Thank you. I'll call. Also I need to know how I mount a different steering wheel.
John
