QUOTE(johnhora @ May 24 2023, 12:41 PM)
Thanks for the info Mark....I had left those out as these were for 914-4...here's the full version
914 Steering Wheel Numbers
914/6:
914.347.803.10 for 914/6 Model 70/71 hard rubber
914.347.806.10 for 914/6 Model 70/71 leather
914.347.805.11 for 914/6 Model 72 leather
914/4 Model 70/71:
914.347.804.10 for 914/4 Model 70/71 hard rubber
914.347.805.10 for 914/4 Model 70/71 leather
914.347.090.10 for 914/4 Model 70/71 hard rubber w/ horn pad USA only
914.347.091.10 for 914/4 Model 70/71 leather w/ horn pad USA only
914/4 Model 72 onwards:
914.347.804.11 for 914/4 Model 72 onwards hard rubber
914.347.090.11 for 914/4 Model 72 onwards hard rubber w/ horn pad USA only
914.347.805.11 for 914/4 Model 72 onwards leather
914.347.091.11 for 914/4 Model 72 onwards leather w/ horn pad USA only
914.347.809.00 for 914/4 Model 72 onwards foamed ring
Any early 914-4 wheel that ends in "10" is identical to a 914-6/early 911 wheel.
Besides not having the two little holes drilled to hold the 914-6/911 cancel ring, the wheels that end in "11" have a slightly different chamfer or angle on the back of the aluminum hub where they rest on the steering shaft. The "10" fits a Porsche steering shaft, the "11' fits VW, though you can make either one work. The switchover point between the 10 and 11 wheels started in the 1972 914's. The '72 914-6 used a VW steering shaft and thus used a 914.347.805.11 wheel.
All correct. Most 911 sites have it wrong.
