So I am putting back together a 2.0L recently rebuilt for a friend and once I got it all back together, and once it started, the engine won't come down below 3K RPM.
I am assuming this is some kind of Vacuum leak, maybe? It runs strong and smooth at 3K but doesn't go down with closed throttle.
SO, the engine is all new and I need to break in the cam, which, while 3k is probably ok, I'd like to get it sorted before I do that 15 min of 2k RPM.
I've checked all the vacuum lines and connections and see nothing wrong. I am thinking to get a smoke machine, or similar to try to see what I may have missed.
I am an L-Jet Guy with little experience with D-Jet and would LOVE some pointers or suggestions.
Thank you in advance and I did do some searches and haven't yet found anything like this.
CupO'Meat!
(the car is a 74 2.0L and I used Jeff Bowlsby's vacuum line diagram to double check)
