QUOTE(Geezer914 @ Jun 4 2023, 11:51 AM)
Anyone know the difference between the 1974 vs 75-76 Ljet fuel injection? 1974 had a 6 pin connector on the air flow meter and the 75-76 used a 7 pin connector. The 74 ECU has only one circuit board while the 75-76 has two. Just curious.
reason for the difference in the pin connector is that the intake air temp sensor is wired separately in the 75s (the extra pin). the temp sensor might also be in a slightly different location within the AFM. not super positive on that, never inspected a 75 AFM but i think that it was slightly repositioned.
also breaks down between calif spec or USA (49 states spec) for each year.
for the 74 L jet its mostly all listed here as to the small differences between calif or USA.
http://www.914world.com/bbs2/index.php?sho...357407&st=0basically they just used the vacuum advance/retard chamber on the distributor as the main emissions device. the 49 state cars have both chambers connected to the throttle body, the calif cars have only the retard connected. the calif cars run slightly retarded in all steady state throttle (engine vacuum) conditions. the 49 state cars only run retarded at idle. i'm not sure if the throttle bodies were different, the PET catalogue says they were. the calif throttle bodies may have had no port for vac advance cast in, or they may have just had it plugged. never seen a 74 calif up close and original so don't know.
but 74 USA had both ports on the throttle body for distributor hook up.
the throttle bodies were flipped in 75. the USA car got the calif set up with only one port and have seen those. they definitely only had one port in the casting. the 75 calif got the tb with both ports that had been used in 74 USA. the port before the throttle plate was connected to the EGR and operated that. the 75 USA car mimics the 74 calif car.
no use was made of vac advance for the distributor.
the decel valve was changed in 75. its a different design. the 74 used the older decel valve design that was on the D jets.
the distributor is the same for 74 calif and USA and the 75 USA.
had an ignition cut (rev limited) rotor.
the 75 californian did not have the rev limit rotor, instead it had a separate fuel cut off switch at red line.
not sure about the interior of the ECU and circuit boards etc. but its a different ECU.
the 74 L jet is the first application of L jet on any engine. essentially a prototype. the improvements would have been coming fast.
no surprise it was updated in 75. VW almost had exclusive use of L jet that first year it was available. most of those updates in design would have been to do with reliability of the AFM and ECU and redesigning components for that reason along with perhaps ease of manufacture? i don't think the mixture settings etc were altered much if it all - but its possible that in 75 more attention was given to dumping less unburned fuel into the exhaust on deacceleration given calif cars were fitted with cats. interestingly the cats on 914s could not make the statutory 50,000 miles required by CARB and EPA so had to be replaced at 30,000 miles as part of the warranty conditions. that only happened if it was still inside the time limit on the warranty.
aside from "accurate" fuel metering the main emission control devices are external to the ECU and operated "mechanically" - ie the distributor vacuum retard or the EGR (along with a CAT) in 75.
IMHO the 74 USA is the least compromised by its emission set up.
it only runs retarded (and hot) at idle. runs advanced at cruise and engine head temps are lower with better fuel economy.
second would be the 75 calif with the EGR. the EGR offsets the retarded timing at cruise and lets the engine run cooler - lowers cylinder head temps. also has benefit for fuel economy. a more complex and costly device that more or less does the same thing as distributor vac advance but cleans up the exhaust.
last on my list would be the 75 USA and 74 Calif as set up originally.
both run hot at cruise as the ignition timing is retarded.
worth noting:
you can easily de-spec a 74 californian.
either unplug the port on the throttle body or fit a 74 two port tb and hook up the distributor advance. presto. you have a 74 USA L jet. which might have been VW's game in 74. easy conversion of L jet to either region - and flexibility of stocks of cars to sell?
i suspect you could do exactly the same thing with a 75 USA spec car.
fit a twin port throttle body either off a 75 california or a 74 USA and hook up the distributor vac can. not a 100% on that but i don't really think anything in the ECU will stop you from doing that. same would go for the 75 californian. take off the EGR and hook up the advance can. presto = 74 USA spec car. someone who is intimate with the mixture settings on a 75 L jet inside the ECU would know for sure. but i think its entirely doable.
