QUOTE(bdstone914 @ Jun 7 2023, 09:05 AM)
QUOTE(porscheteck914 @ Jun 6 2023, 09:06 AM)
WTB : Do we have any Brain surgeons in the club that can repair the rheostat part of the 914 Head light switch ? Last couple of switches I have bought do not have good adjustment. TOO dim then, off , then TOO bright.
thanks and best regards
You can jumper the two wires to keep them full bright. I think it is 56a and 56b.
waste of time this function as the lamps are so weak anyway ,best solution is to add led's then the dimmer can be bypassed as above cause it won't work anyway.
Don't think the switches can be repaired if they have that issue and who is brave enough to open one up....not me so I did when Bruce mentioned a while back.
Cheers.
