grantsfo
Aug 14 2005, 08:26 PM
During my last few runs at todays Marina AX my car was doing some strange stuff. During downshifts the tranny felt weird and right rear wheel would hop. Any ideas?
mihai914
Aug 14 2005, 08:50 PM
CV Joint?
Series9
Aug 14 2005, 08:56 PM
You need a 3.0+ /6 engine, connected to a WEVO-converted 915 tranny w/ limited slip.
grantsfo
Aug 14 2005, 09:26 PM
QUOTE (mihai914 @ Aug 14 2005, 06:50 PM) |
CV Joint? :confused: |
Doesnt feel like a CV joint. No typical clunk clunk. It only does this during hard downshifts. And rear wheel literally hops in the air, with strange tranny feedback (feels like something is bouncing around). I was too tired to crawl around the car today. Will put it up on jack stands tomorrow to figurre this out.
I have new tranny mounts. I was thinking maybe motor mount was loose, but I couldnt find anything with quick crawl under the car.
I did notice I could move the right drive shaft back and forth a little (horizonital movement back and forth about 3/4 inch of free play) left one doesnt move. Is that normal?
grantsfo
Aug 14 2005, 09:27 PM
QUOTE (914RS @ Aug 14 2005, 06:56 PM) |
You need a 3.0+ /6 engine, connected to a WEVO-converted 915 tranny w/ limited slip. |
Know where I can get those cheap?
Aug 14 2005, 10:28 PM
check the rubber engine mounts and rubber tranny mounts (if you still have 'em) ...
BTDT
Andy
kermit
Aug 14 2005, 10:57 PM
Grant, when I read the heading "something wrong" and "ax", I thought you were talking about my driving today.
KenH
Aug 14 2005, 11:49 PM
BOTH half shafts should move.
Ken
Joe Ricard
Aug 15 2005, 05:19 AM
Your engine is for pushing the car not slowing it down. Brakes are for slowing the car down not pushing. SIMPLE.
The NASCAR guys sometimes do this too and break the rear gear pinion. SO don't do that !!!!
I imagine your shocks are not holding the tire to the ground as the rear of the car comes unloaded. More rebound needed.
grantsfo
Aug 15 2005, 08:23 AM
QUOTE (Joe Ricard @ Aug 15 2005, 03:19 AM) |
Your engine is for pushing the car not slowing it down. Brakes are for slowing the car down not pushing. SIMPLE. The NASCAR guys sometimes do this too and break the rear gear pinion. SO don't do that !!!!
I imagine your shocks are not holding the tire to the ground as the rear of the car comes unloaded. More rebound needed. |
Yeah I know, but this was happening as I was braking and blipping the throttle during down shift. My Koni's are relatively new and set to firm in the rear so I dont think it was "driver error". I have been driving 914's for a long time and have never had tranny problems. I think something has come loose or is broken because I could feel the transmission move around. It was happening on my drive home too.
Once it stops drizzling here I'll check it out.
