Triad 2.0 Dual outlet exhaust. I ran these for less than a year and switched to headers. Some cosmetic rust but absolutely solid.
914werks custom hanger Installed and removed. Didn't even take the car off the lift.
Stains Steel J Tubes
New muffler gaskets
$1200/OBO
More to come
This case is stamped with GA in the 1.8/1.7 location. Saddles are good, main bearing bore in spec, has not been cut for thrust.
2.0 Rods I did not measure these. I don't use stock rods. But I'm willing to do that.
$300 if you pick them up
Pertronics 7mm spiral wound ignition wires. Have neve seen an electon. Looked out of place on a MSD distributor $25 +ship
