QUOTE(StratPlayer @ Jun 9 2023, 04:10 PM)
Monitor that comes with the PMB 2258 motor, monitors the vitals of the engine, great addition to the engine.
You know that's just showing off.
The Holley ECU outputs to CAN gauges that you might want to add to the center console.
I didn't know until recently that PMB was using the Holley Terminator X. I've used that on LS3 builds and the first time you see it self program and start up, you throw away all your MS boxes. Your tune will just keep getting better. You have a great controller with that set-up.
You can bung in another WBO2 with a direct wire to a gauge in the console and then compare to what the Holley ECU is reading. Doesn't mean anything but if you see a difference, it will drive you nuts.
Enjoy!!
DaveB
DaveB
