jim_hoyland
Aug 14 2005, 09:24 PM
Been leaning toward using side mirrors that attache dto the triangular front glass. Want mirror as big a 911--must clear the post.
Did see a very nice pair on a Fer ?
Any pictures / suggestions will be appreciated
ArtechnikA
Aug 15 2005, 06:41 AM
DON'T TRY TO DRILL THE GLASS!
place your faith in glue.
i've wondered if an A-pillar mount (a la new Testarossa) would work.
i like the wing window mount in concept but i like that they open, so i'm stuck with other alternatives. the 911 flag mirror is more period corrent for my car anyway...
jim_hoyland
Aug 15 2005, 08:04 AM
Allen, do you have a picture of the mirrors we talked about Saturaday in San P ?
MoveQik
Aug 15 2005, 08:46 AM
QUOTE (ArtechnikA @ Aug 15 2005, 04:41 AM) |
i like the wing window mount in concept but i like that they open, so i'm stuck with other alternatives. |
Your wing windows open??? Or did I read that wrong?
ArtechnikA
Aug 15 2005, 08:54 AM
QUOTE (MW 914 @ Aug 15 2005, 10:46 AM) |
Your wing windows open??? Or did I read that wrong? |
prolly shouldda mentioned: 911.
sorry about the confusion...
MoveQik
Aug 15 2005, 09:06 AM
QUOTE (ArtechnikA @ Aug 15 2005, 06:54 AM) |
QUOTE (MW 914 @ Aug 15 2005, 10:46 AM) | Your wing windows open??? Or did I read that wrong? |
prolly shouldda mentioned: 911. sorry about the confusion... |
Nevermind.....
Allan
Aug 16 2005, 03:19 PM
QUOTE (jim_hoyland @ Aug 15 2005, 07:04 AM) |
Allen, do you have a picture of the mirrors we talked about Saturaday in San P ? |
Here's a pic of one style I liked. I'm trying to find the other pics.
Allan
Other side
flesburg
Aug 16 2005, 04:12 PM
I fabricated the mounts and used a 3M tape to hold them to the glass. Anything much bigger might be a problem.
jim_hoyland
Aug 16 2005, 04:31 PM
Nice; do the posts block the view ?
flesburg
Aug 16 2005, 06:54 PM
The drivers side is okay, but the passenger side give a pretty limited view. I have a 5 panel wink on the inside, and overall have good rearward vision.
I just like the way they look. The little mirrors are made by the some co that makes tornado (sp?) mirrors, and they are cheap, under $20 each. They took a lot of time to make however. The bases are cut out of 1/4" thick plexiglass, sanded and shaped and painted. The mirrors screw to the bases, and then the bases were taped to the window.
More of an unusual look that anything else I have seen, and if you do not like them, no big $ loss.
pjhaun
Aug 17 2005, 10:39 PM
Here is a picture of my car with BMW M3 mirrors attached to wing window with silicone.
Bee Jay
Aug 17 2005, 11:46 PM
I bought pexiglass vent windows and mounted M3 replicas. Check it out here:
http://www.picturetrail.com/gallery/view?p...2754&uid=598455Bee Jay
Rough_Rider
Aug 18 2005, 09:43 AM
Don't have a pic on my work machine.
I made some plexiglass windows, takes about 20 minutes per side.
Drilled them & mounted some carbon fiber formula mirrors, from SPA. Vision is adequate, fiddly to adjust as there's individual screws for each axis.
Looks cool though & the whole things is extremly light.
STL914
Aug 18 2005, 10:19 AM
QUOTE (pjhaun @ Aug 17 2005, 08:39 PM) |
Here is a picture of my car with BMW M3 mirrors attached to wing window with silicone. |
Is that a sun roof in the targa top? And do you have a trailer hitch mounted in the car?
jim_hoyland
Aug 18 2005, 10:22 AM
How much surface area is holding those to the glass ? Nice!!!
pjhaun
Aug 18 2005, 12:45 PM
QUOTE (STL914 @ Aug 18 2005, 08:19 AM) |
QUOTE (pjhaun @ Aug 17 2005, 08:39 PM) | Here is a picture of my car with BMW M3 mirrors attached to wing window with silicone. |
Is that a sun roof in the targa top? And do you have a trailer hitch mounted in the car? |
STL914 (Gary):
Yes to both questions. I adapted a bike rake to the trailer hitch. The trailer was made in Canada and it is basically designed for a touring motorcycle.
pjhaun
Aug 18 2005, 12:56 PM
QUOTE (jim_hoyland @ Aug 18 2005, 08:22 AM) |
How much surface area is holding those to the glass ? Nice!!! |
jim hoyland:
I am at work right now; so I will have to measure the mirrors when I get home. But these side mirrors are also break away. When I push on the mirror with so force they will fold back and then spring back. These particular mirrors have turn signals lights in them. I have them wired up for blue turn signal lights.
jim_hoyland
Aug 18 2005, 06:29 PM
Thanks: do you still have the model/part number ? Checked the Pelican PArts site, they list ( no pictures) several models.
Got a recommended place to purchase ? Are there good used available ?
