QUOTE(Dave_Darling @ Jun 22 2023, 05:01 PM)
Aww, c'mon--you get JOLLY RANCHER candy with your order!!
Do you have anyone in NZ that is really good with old fuel injectors? They'd be the first stop, I think. Sending all four is definitely the best idea, as yours are likely all the same age and have been subjected to very similar conditions. So there's a decent risk the others will stop behaving if you just leave them be. Also if the shop has all four, they can make sure the spray patterns and amounts are identical or as identical as practical.
The injectors are just held in by the rubber seals. The small inner ones locate the sprayer end of the injector in the manifold, and the large ones are what clamps the injector in place. Trivially easy to replace, unless the rubber sticks or the injector cap comes off.
--DD
Yep, have a guy who can take a look.. Hopefully its not broken therwise i'll have to replace them all (to be safe), and like everything else in this country, "its not available in NZ"... so that means extra freight etc.. Thanks for the advice.
