Good morning, so I did Moose but not all of the work on this build, and when I was under the car recently, I noticed that the oil line in the pictures is actually touching the exhaust pipe. That is obviously not good and needs to be corrected.
Because my first 914/6 build I don’t really have experience dies on set up and I’m wondering if it’s simply need to adjust the fittings or if it needs to be something that holds the oil line closer to the body of a car in off the exhaust or possibly a thinner wine used that will create necessary space.
For clarity purposes, I am pointing to the part of the oil return line that touches the exhaust tubing, obviously one is of the fittings, and then the last is where, if it’s not secured higher up the yellow arrow points to where the wine actually touch as the exhaust.
Any ideas or coaching that you all could offer?
Thank you!
