QUOTE(doobie123 @ Jun 26 2023, 05:56 PM)
QUOTE(rfinegan @ Jun 26 2023, 04:26 PM)
Best to block one wheel and turn the other by hand in 5th gear...ez todo by your self or with a helper...
ok, i have also been told that pulling the plugs and hand turning the cage is a good way. is there a "best" way or just a personal preference?
also, any tips on setting the valves would be appreciated. i have never done this on this engine. seems the hardest part is access.
thanks
The bolt is not too big (8mm?) Will not take lot of torque to loosen to break.
Turning the cage is fine if you are in the engine compartment. But the valves are under the car. Getting up and down is the hardest part of the job. Look for the Method on the rocking valve method by Crusty..works well
I turn the engine over by hand till I see a rocker at its fullest open, then adjust the other side. They share a lobe!
A combination of this method and Crusty's will tell you which ones to do so it goes faster...
