Hi all,
I've had this 914 for over 12 years now - bought by myself and my grandfather ( @JDW914 ) as a project back in 2011 - and used it regularly for a decade before a fire damaged a lot of the car's wiring and paint. It was re-restored 2 years ago, and hasn't run since, as we've had a lot of trouble getting it to stay running. I've finally taken full custody of the car and have been digging into trying to figure out this problem in earnest.
Where I stand:
The car is fully restored, and appears to be in strong working order. This is a nearly all-stock 1974 2.0 with an Original Customs 2056 upgrade. No other major changes.
- Compression checked at around an incredible 180# on all cylinders.
- Valve lash is at nominal on all valves.
- All fuel and vapor lines replaced with new.
- Fuel pump wiring replaced with 12AWG for more sturdiness, less resistance.
- Fuel pressure regulator replaced with new, added analog fuel pressure gauge in engine compartment.
- Fuel injectors (cause of the fire) were replaced with SMP FJ67s.
- Distributor cleaned and rebuilt, checked for responsiveness on ignition and FI points.
- All engine bay wiring has been replaced with brand new harnesses (and then meticulously rebuilt and checked for any issues after continued problems).
- Transmission ground replaced with brand new braided strap.
- The ECU (Type-044) (though somewhat charred) was tested by Specialized ECU Repair last year and given a clean bill of health.
- The MPS was replaced with a rebuilt unit correct for the car from a reputable community member.
- All minor engine sensors have been replaced with new and tested for correct responses.
- Throttle body and TPS rebuilt with new board, tested correct.
- Relay board was de-resin-ed, cleaned, and all joints were soldered, with all paths testing under 8Ω (seems a little high, but I guess that's just what solid copper gets you)
No matter what we've done, the car seems to die as soon as it's off the starter. It runs incredibly up until that point, then dies, but not immediately. Sprk continues, and it kind of sputters out. If spark is fairly retarded, it will sputter on for maybe 20 seconds before dying, which indicates spark is not an issue. And indeed, spark from a pulled wire stays strong to the very end.
However, it doesn't really respond any differently if starter fluid is sprayed into the intake manifold. This makes me think air mix might be an issue, but increasing air bleed seems to make it less eager to run rather than more. Additionally, The fuel pump is running, and the main injectors are most definitely firing, as the engine fires up every time, and the cold-start injector has been unplugged throughout my troubleshooting. The ECU has power on both pins 16 and 24.
2 other things do lead me to suspect some kind of fuel delivery issue, though: 1) The engine will run and stay running (BADLY and SMOKILY) with the CHT unplugged and open, and the spark VERY advanced. 2) When I move the throttle with the ignition on and engine off, I neither hear nor feel the injectors pulse.
Buuut, on the other hand, working the pedal while attempting to start the car normally will generally keep it alive longer, up to maybe 30 seconds, and pushing the car with ignition on, in gear gets a kick immediately upon spark, without running the starter circuit.
I intend to test the injectors by unplugging them and actuating the throttle to verify pulsing.
Does anyone have any advice on further tests to perform or ideas on failure modes this might be indicative of? Any sort of advice will be very, very appreciated.
This has been stumping myself, my grandpa, and every mechanic I've spoken with or had look at it for years, but I intend to figure it out.
