Hi fellas, ok next cab off the rank!
Had my injecturs refurbed, so thanks for those who gave some great advice..
Now the fueling is good, its time for the AIR!... Can i get your advice on how you setup the following?
- All hoses attached but when i put my hand over the airbox intake the motor doesnt stall.. (Assuming no air leaks and the only place air is sucked in is through the airbox)
- The air screw valve on the side of the air intake plenum i have set to one full rotation. (closed completey then 180 degree turn open)
- The air seems to be sucking in from around the air plenum/airbox seal (which doesnt seem to be very tight).. Do you guys just put up with it or is there a fix for a better seal?
