This is just my recent experience, so - "buyer beware" . . .I just replaced 914 rear wheel bearings for the first time - the passenger side was completed with a Technician with 30 years of experience with Ford, Porsche, BMW, VW etc. - he laughed when I mentioned freezing the bearings . . .he said something like, "do ya really think we tell the customer to "come back tomorrow, we have to put the bearings in the freezer?"
I took the passenger out with sockets and all thread a year ago (based upon info from 914World/Pelican etc) and had the vintage German-made bearings in the freezer for a year. Yeah - it's been a tough year.
The frozen bearings absolutely did not "slide in" . . .the Tech very carefully hammered the new passenger bearing in to start/square it and then I pulled the bearing in with a front wheel bearing installation kit from Amazon (OMB?) and a seal installation kit to start the bearing (aluminum - from either Amazon or Harbor Freight).
The next night - using the tools above - I pulled the hub in (on the passenger side mentioned above) and did the complete driver side from old bearing removal to new bearing installation/hub installation in 20-30 minutes or so (being quite careful).
Frankly none of the bearings or hubs went in easily or square(at first) - but if you use proper (albeit not premium) tools, the job gets done properly.
Btw-when I took out the passenger bearing last year, I bought a Harbor Freight wheel bearing removal kit, and the threaded rod stripped immediately (hence the ultimate use of sockets, nuts, washers and all-thread), but with the OMB(?) kit from Amazonopoly
, I could even use the impact with impunity . . .much harder steel threaded rod . . .worth the cost.
Freezing seems unnecessary and time-consuming.
I did, however use WD-40 on the trailing arm and hub before bearing and hub installation.
Not sure how much more "all 3 at once" procedure one can get.
