tomeric914
Jul 7 2023, 11:22 AM
Gauging interest in rear hubcentric adapters for the 5 bolt folks. Why only 5-bolt you ask? Because Tangerine Racing already offers an adapter for the 4 bolt folks and I don't want to take away from Chris and all the great things he does for us.
Tangerine's 4 bolt rear hubcentric adapters can be purchased here:
https://tangerineracing.com/shop/ols/produc...centering-ringsIf you have a Porsche 5-bolt setup and are interested in hubcentric adapters, please reply to this thread.
If there is enough interest, I will message everyone individually. I should be able to offer these for $75/pair shipped.
These will be machined out of 6061 aluminumWhy am I doing this? Well, I needed a pair so I designed my own and would like to give back to the 914world community.
This started out with a 3d printed "proof of concept" model shown below. Actual production versions will be machined out of 6061 aluminum which simply fit inside the rotor hat. These will be a clearance fit which may require time in the freezer to install depending on how clean, dirty or rusty your rotors are.
Shivers
Jul 7 2023, 11:41 AM
Very cool.
Montreal914
Jul 8 2023, 11:42 AM
Nice offer.
Can you comment more on the difference between Chris' 4 lug setup and yours?
Since there are a few options of the 5 lug conversion, which will it work with?
For example, I plan on using drilled /4 hubs and 914-6 rotors.
tomeric914
Jul 8 2023, 01:17 PM
QUOTE(Montreal914 @ Jul 8 2023, 01:42 PM)
4x130 cars have a 78.6 center bore (this is what Tangerine offers)
5x130 six cylinder and converted cars have a 71.6 center bore (this is what I can make if there is enough interest)
Both of these fit any stock 914 or pre-1985 911
REAR rotor
Measure the center bore of the wheel that you are using. If it's a 5x130 Fuchs, then it is likely 71.6mm
Montreal914
Jul 8 2023, 01:23 PM
OK! So difference is the the wheel bore ID, not the rotor ID where this piece will nest in. Got it.
I plan on using 16x6 Fuchs.
mlindner
Jul 8 2023, 02:05 PM
I'd be in for a set for my GT Tribute. Mark
technicalninja
Jul 8 2023, 02:29 PM
I'm in!
This is critical if you're using bolts instead of studs.
After seeing the Tangerine units my thought was "Damn, I'm not going to be able to use those due to my 5-lug conversion".
My second thought was "I'm going to studs and it's not as critical."
Now I am...
Hub centric installations are much stronger than bolts/studs alone.
Thank you Tomeric914!
tomeric914
Jul 8 2023, 04:04 PM
QUOTE(mlindner @ Jul 8 2023, 04:05 PM)
QUOTE(technicalninja @ Jul 8 2023, 04:29 PM)
I'm in!
Thanks. If we can get at least 10 people interested, I'll start a link in the classifieds.
technicalninja
Jul 8 2023, 04:11 PM
I want mine slightly interference fit so I have to polish/sand them until they fit in the rotor bores.
I want mine as tight as they can possibly be to my rotors (Setrab 914-6).
As the inner bore of the rotors is not critical different brands of rotors may have slightly different bores.
You might want to check a few brands of rotors to make sure there is not major differences.
Slightly too tight is fine with me...
914Sixer
Jul 9 2023, 12:22 PM
I am good for a pair.
76-914
Jul 9 2023, 02:51 PM
+1
Alain V.
Jul 9 2023, 06:04 PM
great idea. put me down for a pair.
tomeric914
Jul 10 2023, 08:22 AM
QUOTE(technicalninja @ Jul 8 2023, 06:11 PM)
Incorrect. The inner bore of the rotor is a critical dimension (90mm). Later 911 models went hubcentric which is tight to the rotor.
technicalninja
Jul 10 2023, 08:52 AM
QUOTE(tomeric914 @ Jul 10 2023, 09:22 AM)
Great!
They don't matter on a 914 hence my concern.
I restore old cars, not just 914s and have massive trouble with things like this.
I've recently done a 1989 Grand Wagoneer and almost every part was bought from a specialist "Team Grand Wagoneer".
Almost all the parts required some form of fabrication to install. Nothing was dead nut on.
The fuel pump required serious machining of the power steering bracket and made a 30 minute job into a 6 hour job.
tomeric914
Jul 13 2023, 08:03 PM
Finished product machined out of aluminum. About 2 hours in the freezer and they tap right in. End result is no more vibration coming from the rear. 15+ years of fighting that vibration ended today!
Unfortunately not enough interest, so I probably won't make any more unless more chime in. My apologies to the 5 who expressed interest:
Alain V.
76-914
914Sixer
mlindner
technicalninja
Nate W
Jul 13 2023, 09:44 PM
I’m in for a set if you make them
peteinjp
Jul 14 2023, 12:55 AM
I'd be in for a set too.
Pete
mate914
Jul 14 2023, 04:56 AM
I am also in for a set. #9
Now we need one more.
Matt
914Sixer
Jul 14 2023, 08:51 AM
Up my order to 2 so that will put us over the top.
tomeric914
Jul 14 2023, 09:44 AM
Well alrighty then! It'll take me about a week to get these made, so I'll send out payment info and get shipping addresses from everyone in the meantime.
Here's who I have:
Alain V.
76-914
914Sixer (x2)
mlindner
technicalninja
Montreal914 (I think?)
mate914
peteinjp
Nate W
If I have missed anyone, please let me know ASAP!
To be clear, these hubcentric rings are for 914 and 911 rear brake applications which fit the 90mm opening in the rotor. Hub centering rings go in the freezer for at least 2 hours and will tap in, expanding as they warm up to a snug fit. It is important that the surfaces be as clean and rust free as possible so the ring fits and sits flush. Use a wire brush, tooth brush and brake cleaner and a pick to get everything as clean as possible. Test fit was done on factory stock, off brand and Sebro rotors.
technicalninja
Jul 14 2023, 11:40 AM
Outstanding!
Having to freeze the critters for install is what I want.
I'll up my order to two pairs as well.
Thanks
Rick
Montreal914
Jul 14 2023, 11:51 AM
I will take a set please. Thanks you for doing those.
vitamin914
Jul 14 2023, 02:44 PM
Please add me to the list for a rear wheel set.
technicalninja
Jul 14 2023, 05:45 PM
Payment sent on two pair.
Thanks for making these!
Rick
Jul 14 2023, 05:58 PM
I'll take a set ...
tomeric914
Jul 15 2023, 06:23 PM
Thank to everyone who has paid already! I have messaged everyone with instructions who wants a set. Please check your IMs!
I have 12 sets being made which should be done in about a week.
Montreal914
Jul 15 2023, 06:26 PM
jim_hoyland
Jul 15 2023, 06:46 PM
Will these work on any 5 lug rear rotor?
tomeric914
Jul 15 2023, 07:31 PM
QUOTE(jim_hoyland @ Jul 15 2023, 08:46 PM)
"these fit any stock 914 or pre-1985 911 REAR rotor"
"Test fit was done on factory stock, off brand and Sebro rotors."
Spec on the center hole is 90mm. Rotor "hat" thickness is 7mm
jim_hoyland
Jul 15 2023, 09:27 PM
So it wouldn’t be suitable for vented rotors ?
tomeric914
Jul 16 2023, 08:06 AM
QUOTE(jim_hoyland @ Jul 15 2023, 11:27 PM)
911 rear rotors can be vented or solid. Both have the same 90mm hole and 7mm thickness. If you want to be sure, measure yours.
However, as long as everyone pays, I only have a limited number of these being made.
ChrisFoley
Jul 16 2023, 06:19 PM
Someone asked if I would make a set of these for him a few months ago. I got as far as checking dimensions but no further. I haven't had a need to make more of my 4 cyl ones recently, and the lathe has been occupied with other projects almost continuously.
Still not sure if/when I'll get to it, so
to you for running with it.
mate914
Jul 16 2023, 06:57 PM
QUOTE(tomeric914 @ Jul 16 2023, 10:06 AM)
@tomeric914 I had a car fire weekend! I will get payment out tomorrow. Can I get two sets?
Matt
tomeric914
Jul 16 2023, 09:19 PM
QUOTE(mate914 @ Jul 16 2023, 08:57 PM)
Matt
Yikes Matt! Hopefully nothing serious.
I have you down for one set and am only making 12 pairs total. If someone bails, or if I make another run, I can get you another pair.
tomeric914
Jul 16 2023, 09:20 PM
QUOTE(ChrisFoley @ Jul 16 2023, 08:19 PM)
Thanks Chris!
tomeric914
Jul 20 2023, 06:18 AM
QUOTE(Nate W @ Jul 13 2023, 11:44 PM)
@mlindner @Nate WPlease check your messages for payment info
@SirAndy Please message me your shipping address
Optimusglen
Jul 20 2023, 09:16 AM
I missed this thread earlier on, is it too late to get in for a set? If it's not too late count me in!
tomeric914
Jul 20 2023, 04:45 PM
QUOTE(Optimusglen @ Jul 20 2023, 11:16 AM)
Depends on if those who asked for one pay or not!
tomeric914
Jul 24 2023, 09:26 AM
Parts should be completed this week. I will provide tracking to everyone who has paid once they ship.
If you haven't paid yet, see below...
QUOTE(tomeric914 @ Jul 20 2023, 08:18 AM)
dug
Jul 25 2023, 04:28 PM
I'll take a set if someone bails or you make more.
For future reference when making and selling parts, I watch the classifieds more closely than the garage, I'm sure I'm not alone:)
tomeric914
Jul 25 2023, 07:39 PM
QUOTE(dug @ Jul 25 2023, 06:28 PM)
I have one set which I have not heard back from the person who said they were interested.
@mlindner if you are not interested anymore, please let me know and I will offer these up to
@dug I should have these by the end of next week to ship out!
Optimusglen
Jul 26 2023, 02:11 PM
Payment sent! Thank you
tomeric914
Jul 31 2023, 12:29 PM
Received early! I will doublecheck dimensions on a few and get them shipped out tomorrow!
I'll do my best to forward tracking info via PM to those who did not supply an email address.
tomeric914
Jul 31 2023, 03:28 PM
Dropping off at USPS tonight. Check your PMs for tracking info!
technicalninja
Aug 2 2023, 09:08 AM
Got mine!
These are the tightest centering rings I've seen.
Interference fit into brand new 914-6 Sebro rotors. Freezing them should work fine.
Tight fit into brand new Fuchs copies. Really tight!
I'm going to put something on them before I mount wheels, a bit of grease or maybe anti-seize.
They are close enough that any corrosion down the road will stick a wheel.
Bad-assed adaptors!
Better than I would have made.
I'm glad I purchased 2 pair.
Thanks, Tomeric 914!
You should build 100 of them, 50 pair.
You'll sell them all...
Montreal914
Aug 2 2023, 05:13 PM
Got mine today! Very class service and parts! Came nicely wrapped with instructions.
Very happy!
Click to view attachmentClick to view attachmentClick to view attachmentI didn't need to place the rings in the freezer, they went in slide fit. Rotors are Zimmemann.
Click to view attachmentThank you for doing these Tom!
tomeric914
Aug 3 2023, 03:32 PM
QUOTE(technicalninja @ Aug 2 2023, 11:08 AM)
Awesome! I'm glad you like them!
QUOTE(Montreal914 @ Aug 2 2023, 07:13 PM)
You're welcome!
I mounted a new set of 200 treadwear tires up and took the missus out for a ride in my 914. No exaggeration, but never in the 15 years I have driven this car has it ever been as smooth as it is now. One of those "why did it take me so long to do this" moments.
NARP74
Aug 3 2023, 04:23 PM
I have heard there is shrinkage from the cold. Has anyone measured it to see how much?
@tomeric914 Will you be making more?
Steve
Aug 3 2023, 05:24 PM
I'll take a set.
tomeric914
Aug 3 2023, 07:08 PM
QUOTE(NARP74 @ Aug 3 2023, 06:23 PM)
Most materials shrink (cold) and expand (hot). If they are both cold or hot, it's relative, so they expand or contract similarly at their own expansion rates. This adapter is held in place mechanically by the wheel so there is really no concern.
When these are put in the freezer, they will shrink by a few thousandths of an inch making them easier to install. Once they warm up, they are deigned to have an interference fit within the rotor center.
Will I make more? Possibly, if there is enough interest. Looks like there may be a couple interested already.
