sixaddict
Jul 10 2023, 08:27 PM
My understanding is 930 valve covers are the most leak resistant but I have also heard they must be machined to clear the suspension mounting bolt.
Can anyone out there identify where the machining is required.
TIA for any help.
johnhora
Jul 10 2023, 08:48 PM
fixer34
Jul 10 2023, 09:01 PM
You don't have to take that wide of a section off. Here is what mine looks like on the car.
sixaddict
Jul 11 2023, 04:10 PM
Great…….thanks for the help.
Robarabian
Jul 11 2023, 07:09 PM
https://pmbperformance.com/products/930-tur...=42805954379954Deal of the century. 99 bucks each, professionally milled both sides for a 914-6.
I dont have access to a machine shop so this was an EZ decision.
porschetub
Jul 11 2023, 09:19 PM
QUOTE(sixaddict @ Jul 11 2023, 03:27 PM)
TIA for any help.
Click to view attachmentYes they are the most leak resistant with the right gasket,I use the Victor Reinz ones with the silicone bead on them, also be aware that if you buy used ones they may not be flat still,mine needed a quick lapping on a sheet of glass,interesting how the LH milled one required more to get flat ?.
mlindner
Jul 12 2023, 03:38 AM
I had to take a little more off on both sides from what the picture shows. If you can install engine without the covers and then try to fit.....much better then what I had to grind off under the car to remove then for the first time. Best, Mark
infraredcalvin
Jul 12 2023, 08:05 AM
BTW, they only need to be milled if you wish to remove the covers while motor is installed. My 6 is not milled, I drop engine/trans to do valves.
mb911
Jul 12 2023, 03:12 PM
QUOTE(infraredcalvin @ Jul 12 2023, 06:05 AM)
porschetub
Jul 12 2023, 05:12 PM
QUOTE(mb911 @ Jul 13 2023, 10:12 AM)
Thats ok but if you are driving a lot reckon that would be a PITA for such a simple modification,not like its a quick job to remove a 6 cylinder engine unless you have a hoist.
You don't need to use a mill to remove the material ,a grinder flapper wheel will do the same job and touch up with a good flat file.
Certainly a great upgrade over leaking bent magnesuim covers,I resurfaced mine twice and they ended up leaking again after a while.
Cheers.
rgalla9146
Jul 12 2023, 06:35 PM
Alternate choice.
993 covers.
Requires machining for clearance and shorter studs.
Provides modern sealing system.
Jul 13 2023, 04:26 AM
Rory - you would think the modern seals on the 993 engines would be great but we still see leaks from them. One car in particular was a 13,000 mile car.
We have a granite surface stone and it makes a big difference flattening the older style covers. Stick on sandpaper and the sealing surface is flat and clean in five minutes.
mb911
Jul 13 2023, 04:56 AM
QUOTE(porschetub @ Jul 12 2023, 03:12 PM)
Cheers.
I think it’s easier out of the car. It’s too hard up and down In the car in my opinion
rgalla9146
Jul 13 2023, 05:19 AM
QUOTE(mepstein @ Jul 13 2023, 06:26 AM)
Now you tell me !
Is that a consistent issue ?
I'm at 0 mileage...fingers crossed
Jul 13 2023, 07:03 AM
QUOTE(rgalla9146 @ Jul 13 2023, 07:19 AM)
Now you tell me !
They aren’t bad. It’s just not the sure thing you think it would be with that design. We will still often lay in a small bead of sealant to make sure it doesn’t come back 100 miles later. And that’s after cleaning all the mating surfaces really well.
roundtwo
Jul 13 2023, 10:10 AM
New to the 914-6 world.
For Clarification:
With the modified (milled) valve covers, can you remove them all the way to get to the valves with the engine in the car? I'd like to keep the engine installed while I adjust the valves for the first time on my rebuild 6. Have a quickjack. Or is it just to much of a bitch with the engine in?
brant
Jul 13 2023, 02:02 PM
I do the valves on my -6 racecar after every single event weekend
So maybe 5-6 times each summer without removing the engine
Yes milling them allows them to be removed with the engine installed
roundtwo
Jul 13 2023, 07:25 PM
QUOTE(brant @ Jul 13 2023, 01:02 PM)
That’s good news. It looks like a very tight fit trying to access the valves. Imagining your racing an unmodified street body type 914. I have a aftermarket set of exhaust headers heat exchangers that are really tough to get on and off so I’d prefer her not to pull the engine to adjust the valves. Creates a lot of work with the oil cooling lines and all the other items needing disconnecting. Thanks. Todd
brant
Jul 13 2023, 07:40 PM
Unfortunately I do pull the headers off of my car to do the valves on the six
Better than pulling the motor though
infraredcalvin
Jul 13 2023, 07:55 PM
I just drop the engine and tranny low enough to have easy access to top and bottom (8-10 inches or so), car stays on its wheels on a 4 post lift…
sixaddict
Jul 13 2023, 08:31 PM
I am amazed at the number of ways to “ skin the proverbial cat”…..thanks !!!
