Luke M
Jul 19 2023, 06:47 AM
You have two different struts. One is an early ball joint and the other a late ball joint type. The threaded one is the early 901 part # which uses a bolt to secure the ball joint. The late is the 911 part # which uses a pin/nut to secure the ball joint. Hope that helps.
