aeginc77
Jul 21 2023, 09:59 AM
I can't be the only owner of a 914 that has had deteriorating rubber fuel lines but I can't seem to find the right posts covering this. Basically the fabric covered rubber fuel lines seem to deteriorate and split probably as a result of the ethanol in the fuel. Does anyone know if there are any replacements that hold up with the ethanol fuel. I ordered a new 7mm line from Pelican Parts and it seems to be the same German fabric covered rubber that was originally installed.
fiacra
Jul 21 2023, 10:05 AM
http://www.autoatlanta.com/Porsche-914-Fuel-Lines-srch.htmlNot necessarily recommending you buy the kits from AA, but here is a link as a starting point.
Jul 21 2023, 10:26 AM
I’ve bought the ss lines from tangerine racing a couple times. Very recommended
https://tangerineracing.com/shop/ols/categories/fuel-system
BillJ
Jul 21 2023, 10:43 AM
For correct you need to use the fabric covered. However i purchased new lines specifically rated for FI from flaps for piece of mind. This, coupled with stainless steel, was perfect and safe.
aeginc77
Jul 21 2023, 12:05 PM
QUOTE(BillJ @ Jul 21 2023, 12:43 PM)
Could you send link for "flaps" not sure I know who they are.
Thanks
iankarr
Jul 21 2023, 12:59 PM
FLAPS=friendly local auto parts store
ClayPerrine
Jul 21 2023, 01:25 PM
QUOTE(aeginc77 @ Jul 21 2023, 01:05 PM)
Thanks
LOL... I asked that same question years ago on Rennlist. Not the current Rennlist, but when it was a email bbs system before Club/World even existed.
So don't feel embarrassed.
BillJ
Jul 21 2023, 02:09 PM
I used advanced auto. Make sure they sell you FI hose. The carb pressures are MUCH lower.
Jul 21 2023, 02:58 PM
QUOTE(BillJ @ Jul 21 2023, 04:09 PM)
I did the same. I walk in back and pick out what I need from the rolls of fuel hose. They also carry the correct fuel clamps.
BillJ
Jul 21 2023, 03:11 PM
Yes the clamps are important!!! Do not use the crappy ones that are all holes. They will pinch and apply uneven pressure across the hose.
930cabman
Jul 21 2023, 04:44 PM
Napa has always done good by me for fuel hose and band clamps.
914werke
Jul 21 2023, 05:08 PM
Gates Barricade
second wind
Jul 21 2023, 06:08 PM
OK....I just went through this....when I would head out to the car and see a puddle of gas under it it kinda' ruined my mood to even start the car let alone go on a drive. I used the fabric covered lines to be correct and "european" but the ethanol in Los Angeles chews them right up. The fix is using R30 9 fuel line from Gates or Continental.....Cadna 50087 is the Continental brand at advanced auto parts....what a difference!!!! Good luck....doing all of the work under the car left me with a stiff neck...took two months...no leaks now though....Euro trash !!!
gg
jhynesrockmtn
Jul 22 2023, 07:59 AM
AA sells an engine compartment fuel line kit. I've replaced them on a couple of cars along with the tunnel lines with stainless from Tangerine Racing. You'll need a bit of extra hose to do the gas tank to the stainless lines and lines from the rear firewall to the stainless lines Chris supplies that go from underneath the engine to the engine compartment.
aeginc77
Jul 22 2023, 09:11 AM
QUOTE(second wind @ Jul 21 2023, 08:08 PM)
gg
Thanks. Great input
r_towle
Jul 22 2023, 09:34 AM
I got a “kit” from 914rubber
I also had to order the pre bent injector lines from pelican
All new clamps , smooth fuel line clamps, not serrated.
Jul 22 2023, 04:42 PM
QUOTE(jhynesrockmtn @ Jul 22 2023, 09:59 AM)
I’m pretty sure Chris still sells all 4 ss lines. Engine and tunnel. You can call him and ask but that’s where I’ve always bought mine.
930cabman
Jul 22 2023, 04:54 PM
QUOTE(mepstein @ Jul 22 2023, 04:42 PM)
And Chris is a great guy to work with
jhynesrockmtn
Jul 23 2023, 10:34 AM
QUOTE(mepstein @ Jul 22 2023, 03:42 PM)
I just did new lines in my Bumblebee with Chris's lines. The kit came with 5. There is a small reducer that connects to the larger supply line coming from the fuel tank down to the smaller hose size.
L-Jet914
Jul 24 2023, 12:47 AM
I got my fuel line set (still have to install) from Tangerine Racing. I got my fuel hose from Rock Auto as they had the best price per foot/meter at the time Gates Barricade EFI hose. I also purchased a set of fuel injection hose clamp assortment from amazon.
VaccaRabite
Jul 25 2023, 07:08 AM
Do no use the cloth covered fuel line.
Even the stuff they say is rated for Ethanol. Just don't.
First of all, its not SAE rated. And it looks just like the old non-ethanol line. Even if a seller is not trying to get rid of old stock, you don't know what you are getting.
Second, the fabric covering hides cracking issues that may be developing in the rubber, making a visual inspection pointless. You can't see a problem till the fuel line is wet with gas seeping through.
I know this past spring it was hard to find the proper SAE 30r9 rated fuel line locally, but a little calling around found what I needed.
I, personally, will only use a fuel line that has the SAE rating printed on the line.
aeginc77
Jul 26 2023, 07:37 AM
gg
I think I am facing replacing all the lines. Did you have to remove the fuel tank to get to the hoses that go into the tank. My 914 is a 1975 so the fuel pump is in the front trunk but I think I still need to remove the tank to access the hoses. There is a small access plate under the car but it doen't look big enough to easily change hoses. Your thoughts?
Alan
VaccaRabite
Jul 26 2023, 08:32 AM
QUOTE(aeginc77 @ Jul 26 2023, 09:37 AM)
Alan
Yes, you want to pull the tank out. Its not that much effort.
On my tank I put a molex connector on the three wires that go to the gas gauge sender so I can just unplug that rather then un-bolt the filler and all that jazz.
Once the tank is drained (which I do by siphoning out the top) its only about 15 minutes to pull out the tank.
Zach
aeginc77
Jul 26 2023, 10:03 AM
QUOTE(VaccaRabite @ Jul 26 2023, 10:32 AM)
Alan
Zach
Thank you Zach! I appreciate the info!
KYBluegrass
Aug 16 2023, 04:46 AM
Is the original fuel line connections between the tank and the back of the 914 metal? Or does the stainless line option replace actual rubber lines?
930cabman
Aug 16 2023, 04:51 AM
I must say this is one of the easier jobs on a 914. I am new to the 914 crowd, 3 years and was hearing all this and that regarding the original plastic fuel lines. Looking at the project my gut was saying this will be a major pita job. Once I got into it the job went very well, in part due to Mr Chris Foley down at Tangerine Racing. Yes the fuel tank must be removed.
Freezin 914
Aug 16 2023, 06:15 AM
QUOTE(KYBluegrass @ Aug 16 2023, 05:46 AM)
The stainless kit everyone is talking about replaces the fuel lines in the tunnel. The original are a plastic material. There are a couple more stainless lines in the engine bay as well, but most are referring to the tunnel in particular.
Freezin 914
Aug 16 2023, 06:18 AM
@VaccaRabite please tell me more about the molex connector. Sounds like a very good idea. Maybe a picture if available….
MikeK
Aug 16 2023, 08:32 AM
VaccaRabite
Aug 16 2023, 08:36 AM
QUOTE(Freezin 914 @ Aug 16 2023, 08:18 AM)
Its really easy, and there are a TON of 3 gang connectors on the market right now. I used Molex as I could find it easily at Radio Shack (which is also a hint at how long ago I did this - all the local shacks have been gone for ages here). But really any 3 pin connector will work, including just crimping on male and female spade connectors. Just make sure they are shrink tubed so they don't short against each other.
Zach
BillJ
Aug 16 2023, 08:52 AM
Molex
Freezin 914
Aug 16 2023, 08:39 PM
I like the idea. Thank you.
Rufus
Nov 18 2023, 08:09 PM
Molex / AMP connector need? A difference between years or between -4’s & -6’s?
I have the gas tank out of my ‘70 914/6 for cleaning, fuel line replacement, etc. The wiring harness has an electrical connector that easily plugs & unplugs to / from the gas tank level sending unit.
Further clarification may help future readers …
