QUOTE(technicalninja @ Jul 24 2023, 03:49 PM)
That is EXACLY how I bed in every single brake job I do...
Doesn't have to be race pads at all.
I will bed my R4-S pads that I have for my 914 this way.
This way ELIMINATES comebacks on anything.
Rear brakes are much harder to bed than fronts.
Rears usually run 1/3 the heat that the fronts do, and you need to get the brakes hot enough to create the "burning hair" smell.
When the rears are hot enough, the fronts are at excessive temps.
I don't worry about rears as much as I worry about fronts regarding bedding it.
After you've cooked everything up nicely you drive it for 10+ minutes without touching the pedal at all so you need to plan your route accordingly.
If you come to a full stop when hot the pads will "print" to the rotors and you're screwed...
The pads can be saved by lightly touching them to a large flat sanding disc.
The rotors have to, at a minimum, be bead blasted or better to be chucked back up on the lathe and .001 taken off of both sides to create a new bedding surface.
Pain in the ass so DON"T ever stop during the cool down phase.
We have a marvelous twisty county road #4 that runs from Acton to Cleburne (15 miles+) without a single stop sign/light and with a 60-mph limit. It doesn't have much traffic either.
It's my suspension testing and brake bedding road.
You CANNOT have anyone behind you if you're doing this stuff.
"there's a crazy man in a Porsche running down 4 slamming on the brakes and then drag racing back up to excessive speed. It must be drugs or alcohol, Officer."
After the cooling period I'll test the brakes, first softly with hands just lightly gripping wheel. Both application and release are important to not make car swerve on way of another (checking for caliper drag) and then I'll start checking control during application. Brake modulation is critical for me here. Easily controllable application of force and release is what I am hunting for.
Any issues sends it back up on the lift for serious inspection.
I just want to clarify - for me and everyone who reads this thread . . .
You appear to mention the bedding procedure for Porterfield race pads . . .
This thread is about the official bedding procedure from Porterfield regarding their R4-S pad.
Porterfield says, in essence, their is NO bedding procedure that should ever be applied to their R4-S pads.
Just drive your Porterfield R4-s pads normally for at least 100 miles - do not make any hard stops (unless, obviously, for emergencies), and don't hold the brake pedal on during stops.
