QUOTE(HansJan @ Jul 26 2023, 09:07 PM)
I wonder if it would harm the transmission if towed for long distance (but that would be the same on a dolley).
No. Just ensure it's in neutral lol
The reason there's a select group of cars that can be flat-towed behind motorhomes is because they're almost all automatic transmissions. And different cars lubricate the auto transmissions through different pump designs; for example some require the engine to be running. Then you'll get into the types of four- or all-wheel drive but that's none of our business...
Since most (I hesitate to say "all" but it's damn close) manual transmissions are splash-oiling, your transaxle will be lubricated fine, just as if you were driving down the road in neutral.
I suppose you could accidentally tow it in a gear, and the engine spinning the oil pump would lubricate the engine. But just think about driving that diesel-pusher down the highway at 70mph, only to realize that you left the 914 in second gear (my guess, roundabout 9000 RPM, if you got there before it started tossing out bits). Don't do that. - GA
Edit: I thought I remembered reading about something like this...
RV Driver Annihilates Their New Jeep Wrangler by Flat-Towing It in 4-Low
https://www.thedrive.com/news/39794/rv-driv...ing-it-in-4-low
