Basically over old tach's that fail due to 50yr old components,certainly had my share of issues with them ,the wise mans fix is a replacement of the driver board ,have worked with Bob @ ashlocktech for a long time first by buying his tach adapt then he assisted me with the best "bits" for my 911 ignition and my current work with tacho driver board .
For you 4 cyl guys its relatively cheap to buy a replacement and you will be sorted but 6 cyl tach's are becoming more expensive in working condition for example a silver base needle will still need bezel removal and interior clean due to the way they mount in a 911 which is open in the trunk.
My solution was to purchase Bobs driver board and get a company in my country to delete the old board for the new one , calibrate and reset needle damper and ready to go for a modest price,really happy.
First pic is old driver board and next with new one fitted.
Bob has been really great thru my processes ,highly recommended,will update as other work on the go.
Cheers.
