QUOTE(DC_neun_vierzehn @ Jul 31 2023, 07:03 PM)
QUOTE(Rrrockhound @ Jul 30 2023, 12:07 PM)
Like the title says. I had reason to believe my old ignition switch was failing, so I ordered an OEM Porsche one from our hosts and installed it a couple of weeks ago. I started the car with it probably less than a dozen times when suddenly it wouldn't start anymore. I drove myself crazy trying to track down the fault when finally I traced it back to the switch. When I swapped the old switch back in, the problem was solved. Now I'm skittish about ordering another one. If an OEM part lets you down after less than a dozen uses, do you roll the dice on another one?
Well this just made me slightly depressed.
After I get the new heat exchanger delivered and mounted, finish my hurdle after hurdle door/windows restoration project, I was going to tackle my broken ignition switch.
I ordered a genuine Porsche switch after reading endless threads here and on the Pelican board.
This is the first I've read that the genuine Porsche part is junk. Plenty of commentary on all of the non-genuine Porsche parts ignition switches (made in China) being hot trash.
Uggg.
Please keep us updated on your journey here so we can learn from it.
Thanks,
Kris
i found several german made switches, i put one in the car and 2 in the tool box that i keep in the car.
here is a link for a german made one-
https://partworks.de/en-en-en-en-partworks-...ion-switch.htmlmy original one was in the car still until last year, then replaced with a cheap one, lasted 2-3 months had to replace it, put in a used one but OEM german from a local mechanic looked new, no issues with it. when the car didnt start due to a failed solenoid i thought it was the ignition and pulled it and put in another but found the solenoid was issue , so i have new german one in car, used one in the box as a spare, with no issues since putting that in along with my original starteer and solenoid. but i might do the ford relay install for some extra piece of mind. just remember the new starters that are out there their soleoids are nto good, i had 2 fail in 2 months time.
