I would like to know a measurement on your 914. This is a '75 and the right side has some re-work so I'm not able to get a good measurement for the left side inside wheel well distance. This is the measurement I'd like to get (Example is from the right side is approx 9.5"):
This is what I get the left side - approx 10.25":
I used the center of the top of the wheel well lip for these measurements (I've got most of the fender damage out in this picture):
The inner wheel well difference between right and left was initially 1.35" and I've shrunk the fender to a difference of .75". I have more work to do on this fender but I'm trying to figure out if the right side might need to come out a bit and the left side should bend in something far less than .75".
I'm dealing with multiple bends, some trace to an accident, some trace to a repair shop. The left fender was sculpted with bondo. After stripping, I could see all the issues. The picture below was just before I started on the metal work. So the symmetry is off and trying to compare right and left sides can be tricky.
What I noticed was the top of the rear fender looked like it was twisted. It's actually bent at this point on top from a bend in the inner wheel well.
Inner wheel well bend. This caused the oil can look on the top area of the rear fender:
I've got the inner wall flat with an only a small low spot left (backside can't be accessed for a dolly unless I want to remove the spot welds and section out the area). There is this weird spot weld on one side (pictured below). Does anyone also have this?
After hand working the metal, the geometry from the center of the car to the rear suspension is correct (at least the same for both sides). So the body does not appear to be twisted or bent out of square. Now I just want to get the wheel wells to approx where they should be before moving on.
Thanks,
DaveB
