QUOTE(technicalninja @ Aug 2 2023, 12:46 PM)
! didn't answer the original question.
It's easy to add a relay that gets its activation leg power from the original fog lights when on. the ground side of that can be wired into a hidden switch under dash.
This way the extra fogs will only activate when the original fogs are on and the microswitch has been triggered to ground.
The power for the lights themselves can come from an under-utilized fuse in the fuse box or direct from battery. If direct add an in-line fuse to this circuit.
The relay activation power can come from anywhere. The fog light circuit, another fuse that's hot with ignition on or direct from battery.
The fog light circuit means ONLY when orig fogs are on.
The hot in ign fuse is whenever the car is on. They can be used as daytime running lights like this.
Direct to battery is all times on and only turned off when the micro switch is open.
This will often lead to a dead battery if you forget to turn them off. I would not wire it this way, but it will work fine.
The rear defroster circuit might be an excellent choice. I'd have to looks at how that circuit runs in car. This circuit should have pretty good amperage delivery as it ran a heater.
If you use LED fogs the power requirement goes WAY down and wire size is less
important.
The relay will need .2 amps or less to trigger. Running the relay trigger power off of the original fog light feed will not affect the output of the lights.
Hope this helps.
Rick
Yes, very helpful Rick - thanks. I'm sure I won't be running straight off the battery which is why I'd like to use the stock switch and relay from the later '74 harness that I have. I need to learn how to connect them to what's already in the '72 harness/fuse box tho. I know you sort of explained it, but you obviously know the electrical angles better than me. For instance would I be cutting the red/white switched power wire from the stock fog circuit and tapping into, twisting on a power wire to the ('74 relay) aux. lights relay? ..or just power the new added relay thru it's own fuse via an open spot on the fuse block? - Oh, I have extra fuse panels too and have been contemplating cutting one of them in half and mounting somewhere under the dash to add extras to (in the case of this car - aux. fogs, intermittent wipers, electric washer pump, maybe: voltmeter, electric antenna, etc).
Also, I don't think that the '74 came with rear window defrost, but I will look at that harness again.
