For replacing the floor boards - it's what George said.
I saw something in your picture that I wanted to point out. The frame under the hell hole behind the jacking point may need to be replaced or repaired. On mine, I ground the cover sheet metal off to find everything inside rusted. After dipping, you can see the damage from the hell hole which leads right into this area.
Tap the metal around that area in the 914 and listen for the thud when you go over the area I pointed out.
Click to view attachmentSitting out in the Dalles for years ate out the 914 I picked up. It's not difficult to replace this damage if you have the time and place for it. If you can drill or punch an 8mm hole and do a rosette fill you're 90% there. Once all the paint and bondo was removed, I ordered about $4K in sheetmetal. I'll have several hundred hours into the bodywork when I'm done. I say that I'm on the extreme side of repairs, your milage may very...
DaveB
